Using Clari API
  • July 17, 2024
  • 6 replies
  • 2165 views
I am trying to use Clari API, but I am getting errors from the client side.
I have already generated a token.
Can you please provide a short example of using the API? just a simple request.
Thanks,
Shahar.
Best answer by Steve Overton
Hi @ShaharP ,
Here is a simple Python code block, you will note that this includes all of the types to export and that the forecast ID is not set, as this will be unique to your environment, as will the be the API Key:
import requests
url = "https://api.clari.com/v4/export/forecast/<forecast_name>"
payload = "{\n \"timePeriod\": \"2020_Q3\",\n \"typesToExport\": [\n \"forecast\",\n \"quota\",\n \"forecast_updated\",\n \"adjustment\",\n \"crm_total\",\n \"crm_closed,\n ],\n \"currency\": \"USD\",\n \"schedule\": \"NONE\",\n \"includeHistorical\": false,\n \"exportFormat\": \"CSV\"\n}"
headers = {
'Content-Type': 'text/plain',
'apikey': '<api_key>'
exportresponse = requests.request("POST", url, headers=headers, data=payload)
print(exportresponse.text)
This code generates the request, you can pull a list of jobs running or completed with the following code block:
import requests
url = "https://api.clari.com/v4/export/jobs"
payload = {}
headers = {
'apikey': '<api_Key>'
jobresponse = requests.request("GET", url, headers=headers, data=payload)
print(jobresponse.text)
Finally, to pull the results for your export job, you can take the ID from the list, or from the ID returned by the initial code block:
import requests
url = "https://api.clari.com/v4/export/jobs/<job_id>/results"
payload = {}
headers = {
print(response.text)
Steve Overton - Sr Technical Support Engineer - Clari
  • July 17, 2024
Hi, @ShaharP. This’ll likely depend on which data warehouse/BI tool/analytics tool you are using. I would recommend opening a case with our support team with the specific error messages you’re experiencing to get some help!
  • July 18, 2024
I'm just looking for short code examples in any language (preferably Python). Due to the fact that I could not find any examples in the documentation or on the internet, I believe that other people will find it useful as well.
Hi @ShaharP ,
import requests
headers = {
import requests
payload = {}
headers = {
import requests
payload = {}
headers = {
  • July 21, 2024
Thanks Steven! It works!
Can anyone advise why this payload causes a malformed API response? I am following the docs and receive errors every time, but don’t receive any errors when I remove the payload. Thanks
payload = {
'timePeriod' : '2026_Q1',
'typesToExport' : ['forecast'],
'currency' : 'USD'
headers = {
'apikey': key,
'Content-Type': 'application/json'
response = requests.post(url, headers=headers, data=payload)
  • February 4, 2025
Hi, ​@Michael Duffner — It could be that the apikey section doesn't pull the variable you have set. However, to be certain, my best suggestion would be to open a case with our Support team. With your org details, the support team can test to confirm.
