Sentiment Filter
  • April 23, 2025
  • 247 views
ryan.costello
Regular Contributor
Forum|alt.badge.img+9
Which of the filters include the optional Sentiment filter? For example, I know that if I select the Competitor Mentioned filter it reveals Spoken By and Sentiment fields as well. Are there other filters that have the Sentiment option?
Hi, ​@ryan.costello! The Sentiment filter only comes with the Competitor Mentioned filter today. If you have any other filters that you’re thinking it would be helpful for, let me know and we can share that feedback with our Product team.
  • April 24, 2025
ryan.costello
Regular Contributor
  • Regular Contributor
  • April 24, 2025
Thanks for the quick clarity, ​@Kenna !
