Groove flow question
  • March 4, 2025
  • 4 replies
  • 265 views
Why can I only add 100 contacts in a flow to a CSV, at a time, or if adding 400 to a flow, why can i only add 1 page at a time?
Would make more sense to add all of them at once, unsure if i am missing something
Any help would be appreciated it please
  • March 5, 2025
Hi, ​@StevenWren! To clarify, are you trying to upload people to a Flow using a CSV Lookup, or are you trying to export a CSV of the people in one of your Flows?
  • March 5, 2025
Hi Kenna.
My flow has 400 people in it, but it will only let me select 100 people at a time to either move to another flow or download in a CSV, rather than everyone in that flow.
Ideally I can select everyone at once, then put them in a CSV and add them to the next step. which is greyed out also in this flow
  • March 5, 2025
Hi, ​@StevenWren — Thank you! You’re right that the People tab in Groove is paginated today, and I completely understand how the experience of needing to export each page when there are more than 100 people in a Flow is not ideal. What I can recommend is that you submit an idea as feedback here in the community. It’ll go directly to our Product team’s feedback repository so that we can track it in relation to our product roadmap so that you have visibility here.
  • March 6, 2025
Done - thanks Kenna
