How to insert a scheduler link in a master flow?
  • November 12, 2024
  • 178 views
Hey all - I’m new to Groove and I’m trying trying to build a master flow that many of my reps can use.
We previously used Outreach and would frequently include the variable {{sender.calendar_url}} in flows to allow multiple people to use the flow and include their personal calendar/scheduler link.
Is there a merge field like this for Groove?
Hi there, @AnnaN!
You can do this today, although you’ll need some help from your Salesforce team (if you’re not a Salesforce admin) to create a custom field on the User Object in Salesforce. The process is outlined in our knowledge base here. If you already have that set up, then it should be good to use in your flow now. The exact naming convention for the merge field will depend on the field you created in Salesforce. Note: After the field has been created, it can take up to 24 hours for the merge field it to surface in Groove because that's the interval on which the Groove <> Salesforce metadata refreshes, but you can also expedite that process by navigating to this link to manually force a metadata refresh if you want the field to show up ASAP.
  • November 12, 2024
Hi there, @AnnaN!
