Clari box color
  • April 22, 2024
  • 210 views
Something changed in my view where the entire box used to be the full color and now it’s just a triangle in the bottom right.  How do i switch it back so that the whole box is colored.
Best answer by Scott K Wilder
@David Gardiner
Normally, this is how you fix it.
Go to
  • Top right initials icon
  • Preferences
  • Check full cell highlighting
I say ‘normally’ because there is a known bug about this -- the team is working on fixing.
Scott K Wilder
Expert Contributor
  • Expert Contributor
  • April 23, 2024
@David Gardiner
Go to
  • Preferences
  • May 28, 2024
Same for me. CSM says this is the new design. Argh...
