Show Reps with no Pipeline for Next Q
  • May 15, 2023
  • 133 views
Lala Djafarov
Forum|alt.badge.img+2
Is there a way to show on a chart (that then will be pinned to a dashboard) - people that have no pipeline for next quarter?
If I create a straight forward chart of open opportunities it will leave out people with 0$ Pipeline.
Thanks!
Hi, Lala! If you are curious to learn more about forecasting pipeline for future quarters to gain visibility into this (as Ty mentioned), this webinar recording in our Knowledge Base is a good overview. Check it out here.
Ty Lapinski
 Hi @Lala Djafarov,
Unfortunately, our charts widgets will only return results if there are records associated to the owner. You can create an Idea for this improvement to display users with $0 pipeline.
Another place to gain visibility to a user with $0 pipeline would be in Forecasting since we display all users and their associated pipeline even if $0.
Hope this is helpful!
  • May 23, 2023
