How To Clean Up Flows Within Recently Implemented Organization
  • March 28, 2024
  • 123 views
What is the easiest way to clean up an organization’s flows that are not getting used? We recently went through implementation and some of the old flows/sequences we migrated into Groove are no longer needed and seem to be adding a lot of clutter.
Best answer by Scott K Wilder
@Gretchen_Miller Talked to the Groove team and they recommended that you archive the flow(s), but make sure there aren’t any active prospects in it.
You can work with your CSM on how frequent you should do system clean ups (monthly, quarterly, yearly, etc)
Scott K Wilder
Expert Contributor
  • Expert Contributor
  • April 2, 2024
