Groove dimensions for a .jpg header?
  • May 23, 2024
  • 51 views
Hi,
While we use Groove for 1:1 communication for our BDR team, we want to experiment with a couple of generic/marketing emails in a flow. Has anyone tried this? Also, what dimensions would be used for a header/logo?
Thanks!
Hi @JohnA! Attaching some general best practices on Groove Flows, but I would also love to hear how others are building Groove Flows for this use case.
There is a 10 MB file size limit on any image that you add to Groove email templates, but otherwise you can use whatever images (or GIFs) best suit your needs, and even edit the HTML directly if needed.
  • May 24, 2024
