Forecasting Products in Clari: The Step by Step Discovery Guide for Admins
  • January 18, 2024
  • 265 views
Ash_Jordan
If you are tracking products/product families in your CRM, you might be interested in evolving your forecasting process to be more precise and segment forecasting by products. 💡
Clari can help you achieve this by configuring the Forecast module to surface insights about your Products. Here is a quick introduction to this concept in Clari as well as what to expect operationally:
  1. Introduction: Watch the Product Level Forecasting Webinar (15MIN, + Q&A)
  2. Review the post, How do I forecast by products?
  3. Confirm answers to the following basic requirements:
    • Product Filters  - How do you define each product or product line?
    • Product Filter Segment - Are products also bundled into 'product families'?
    • Relevant Amount - What amount field do you aggregate on?
    • Forecasting Cadence - Who is responsible, is a Forecast call required?
Example from Clari Demo Environment:
THE DISCOVERY PROCESS: WHAT TO EXPECT NEXT?
Now that you’ve learned some of the basics and consolidated the foundations of what is required, for new forecasting use-cases we recommend approaching this by:
  • Schedule a Discovery Call with your CSM/SE to review your requirements
    • Confirm 'What is the end goal?' for the new Forecast Motion
    • Identify which teams expect the value add
    • Define what net-new is being built: [IE: New Mode, New Forecast Tab]
    • Know what your timeline is to deliver to the business
  • Assess configuration process: Self-Serve (DIY with CSM Consult) or, Done for you (SOW- Professional Services Managed )
Let us know what you think in the comments! ⬇️
  • January 19, 2024
I love this guide, Ash! 🙌
If you’re an admin seeking to understand more about how this and other forecasting tabs work in Clari, check out our Forecasting Fundamentals Certification Path in Clari University.
