FAQ: How do I A/B test to an email step in my Groove Flow?
  • April 21, 2025
  • 134 views
After creating the initial steps of your Flow, click the ellipses next to the step you want to A/B test. Then, choose Add Template to insert another template. Groove will split the contacts between the two templates for you.
