Extract Deal Activity (without having Acc Eng.)
  • May 10, 2023
  • 161 views
Lala Djafarov
Forum|alt.badge.img+2
We don’t have Account Engagement, but our reps inboxes are connected and we’re pulling and viewing the deal activity per each opportunity.
I would like to extract this raw data - but it’s not available on opportunity exports.
How can get it?
Best answer by Ty Lapinski
Hi @Lala Djafarov,
Great question! We can add the activity counts to the export from the Opportunities module if requested. If you open a case with our support team, they should be able to enable this feature for you on the backend so activity shows in your exports. You can also reference your community post to the team when submitting your case.
Note: the reason this feature is not enabled by default is it will create a larger file and take longer to run the export job. It is expected that these export could take longer with this feature enabled.
Happy to answer any other questions around this topic if you have them.
Cheers!
Ty Lapinski
  • May 12, 2023
Hi @Lala Djafarov,
Cheers!
Lala Djafarov
  • May 14, 2023
@Ty Lapinski  Great news!
I will go ahead and request that immediately :)
