Do Viewer Users Need a CRM License too
  • March 13, 2024
  • 175 views
Do Clari users, who are just a “viewer” vs. a contributor or manager, need a Salesforce (CRM) license as well?
Thanks in advance!
Hi, @David Divan! So you do at minimum need a standard Salesforce license in order to login to Clari as Clari inherits your user permissions from Salesforce (i.e. which opportunities you can see).
  • March 13, 2024
