Importing CRM fields for Stronger Call Segmentation and Analysis in Copilot
  • June 27, 2025
  • 163 views
Rohit Agarwal
Forum|alt.badge.img+11
When looking at your Team Calls in Copilot, have you ever wondered if you could filter this list to only look for calls with your customers vs prospects ? Or filter out all ‘Enterprise Deal’ calls or calls with opportunities >$100K ? Or even look for calls where the CRO or an Economic Buyer was an attendee? If yes, you’ve come to the right place! See below 👇
Copilot's “Import CRM Fields” feature allows you to import CRM fields from the following CRM objects (Account, Opportunity, Contact, Lead) to be used as Call filters. The idea with having these CRM fields as filters is to help you segment your list of calls so that you are able to narrow down to the right set that needs your review or attention. For example, if you are looking to analyze all calls where the deal was lost due to missing product features or capabilities, having CRM fields such as “Deal Stage” and “Deal Lost Reason” as filters can help you filter out calls associated with related closed lost opportunities from your entire call library.
Curious to know how you can configure and import these fields? See below:
AD_4nXd2GZjv_KQuI89KATwyWaQNSLOANGHYReOeRioIeVF7VqW9qnwOYvQp23RffUhyJA41Ci8i3n2j0eZODsuVtxayIIPZScWHKf2rmiVoYHi5jsYEKvauMRZEj7VHv0XsXuO9x-XxbQ?key=KGm67MkCUTjRlDp3GFgnAw
Once configured, this is how you will be able to see and use the different fields as call filters:
AD_4nXfgTliXucrgujQf4QewnN0WnJy8uOdtWzhV30ItlD3XiH1S91nZNcs7UKPck3-kQvys4k4BCdKyZ0Vb8U1tTor6i2HhX0qIZky1ZJsOcr6P5RmF3fsjisiHPGbWDZl2FrnXr4OSXA?key=KGm67MkCUTjRlDp3GFgnAw
Listed below are a few more examples or use cases to help you get a better understanding of how you can run stronger call queries using the CRM field call filters:
Use Case 1: Filter for a list of calls related to a particular Account:
AD_4nXdwAhIY323clqcP3MrFgpKQEv85QfgRLpxXtYh3gR7h-D99pdEfR_ozh6jC4sdadTCD0VYkLGCdP-2TplCfH_46KIZuLGW9QjtVly64hHnvsmMe4cNIg67AwJZXyQ4yOn0IXkhQDA?key=KGm67MkCUTjRlDp3GFgnAw
Use Case 2: Display the list of all calls with a particular Customer Account in which one of the attendees has the title of “CRO”
AD_4nXdz55v_z4aNwA92VYpeTDR9zcyfl8Pgt0c7JUe4Ei7aGtUivewhZhyg_Q5RoraxbN5CWT-7ctSEM9B_d_OOuwfr_rV6y-6G6AmpgK2WmtrjvGetXiWJ7XP9Zk2RO2OlpYK5mbxxEw?key=KGm67MkCUTjRlDp3GFgnAw
Use Case 3: View the list of calls with Opportunities that are in “Commit”, a Competitor is involved, and the Deal Size is < $1M
AD_4nXcGy2QAsROZsJfSASClbV-SwTAekKLsmo76IT53LwR2casqycYbpSKSuPvqvtemPszYFnkI2VmyNNDXH3lDnGvlmOk08PlukXUy5uMpEGfUrmQdZs7zYxMQmLG8eURmrjRAe0eI?key=KGm67MkCUTjRlDp3GFgnAw
Below are examples of fields that we typically recommend to import across the 4 supported objects (Accounts, Contact, Opportunities and Lead)
  1. Account: Fields like Account Name, Account Type, Account Health, Segment, Account Owner, Billing Country etc
  2. Opportunity: Opportunity Size Or Amount, Stage, Forecast Category, Type, Competitor Involved, Close Date, Lost Reason, Slipped Reason,
  3. Contact: Title, Role/Persona Type (Economic Buyer, Champion, Decision Maker, Influencer), Status
  4. Lead: Title, Role/Persona Type, Intent to Buy
Hope this helps! If you have any further questions, please reach out to your Clair Account team for more information.
What CRM fields are you going to import? 😊
