Configure Copilot Conversation Intelligence Data in Capture Studio (Legacy Capture customers)
  • August 22, 2025
  • 428 views
Vinay Srinivas
You can now configure all Copilot data fields directly in Capture Studio Configuration in a completely self-service manner.
Note: This feature requires a feature flag to be enabled. Contact your CSM if you don't see these options in your configuration panel.
📋 How to Get Started
  1. Navigate to Capture Studio Configuration
  2. Select Activity Logging
  3. Go to Advanced Settings
  4. Click on Copilot Meeting Settings
⚙️ Configuration Options
Enable Copilot Meeting Data Logging
Simply toggle whether you want to log Copilot meeting data. When enabled, all 13 supported Conversational intelligence data fields will be automatically populated. When selecting the field in the configuration, if the desired write back field is not in the dropdown, then it may be necessary to create a new field in SFDC and grant access to the integration user.
Field Mapping Made Easy
  • Get a comprehensive overview of all supported fields with their data types
  • Enable or disable individual fields (all enabled by default)
  • Map CI data fields to your Salesforce fields using our intuitive dropdown menu
  • Only compatible field types are shown in the dropdown for seamless integration
Special Note: Smart Summaries automatically map to the 'Description' field by default.
📊 What CI Data Fields Are Available?
Here's what you can now capture and configure:
Field
Description
Call Duration
Call length in seconds
Call Type
Platform used (Zoom, Google Meet, etc.)
Location
Call location information
Host Questions
Number of questions asked by the host
Client Questions
Number of questions asked by the client
Competitors Discussed
List of competitors mentioned
Topics Discussed
Key topics covered in the call
Call Link
Recording link for reference
Interactivity Score
Rep interactivity rating (1-10 scale)
Smart Summary
AI-generated call summary
Engaging Questions
Questions that prompted 30+ second responses
Longest Monologue
Duration of longest uninterrupted speech
Talk-to-Listen Ratio
Balance of speaking vs. listening time
💡 Enhanced Activity Logging
Once configured, your CI data fields will:
  • ✅ Appear as separate columns in the Activity Logging Grid
  • ✅ Support column operations (insert, hide, move, drag & drop)
  • ✅ Be included in Activity Logging exports
  • ✅ Enable search functionality for 'Competitors' and 'Trackers'
🔍 Important Notes
  • Character Limits: Competitor and tracker names are automatically truncated at 255 characters due to Salesforce text area limitations
  • Smart Prioritization: When tracker fields exceed limits, we prioritize the most frequently occurring trackers
  • Seamless Integration: All data syncs directly to your Salesforce fields as configured
🎯 Ready to Get Started?
This powerful feature puts you in complete control of your conversation intelligence data. Configure it once, and let automation handle the rest!
Have questions or need assistance with setup? Drop a comment below or reach out to our support team.
